1993 115hp engine died on lake
Party hut Chris
out yesterday with the family, and my 115hp outboard was running fine, then just "tired out" and stopped. New battery, turns over great but won't fire- had to be towed back to shore...what the heck?!? Family coming in for Memorial Day- I need this thing to work! Help?
Drain a carburetor and look for water.----------Does primer bulb go hard ?-----Check for spark on each plug lead.---------And does spark jump a gap of 7/16" on each lead, yes or no ?
Party hut Chris
Hey Racerone- changed out spark plugs, and running well now. Question though...primer bulb does NOT get hard even with lots of repeated squeezes...problem?
emdsapmgr
The primer bulb should get hard the first time you pump it at the start of each boating day. Once the engine starts and runs, it will start to draw fuel through the hose. The bulb will soften, but should not collapse on itself. That's normal. If the bulb never gets hard, try holding the bulb so that the arrow on the side of the bulb is pointing skyward-when squeezing. (that arrow needs to be pointing in a generally upward orientation.) If the bulb never gets hard, it's possible the ball valves inside the bulb may be bad and the bulb may need to be replaced. The bulb may also not function normally if it's laying downhill in the splashwell of the boat. Sounds odd, but the orientation of the bulb is important, esp on older hose bulbs.
