Thanks. That isn't to say it is not firmed up in the front some. it isn't a completely open bow. check out the pictures and see the closed bow? interestingly that isn't the original material. the original thin aluminum is under that, but the actual bow top is now a nice piece of much thicker aluminum, the rear edge is folded down to bolt to a bulkhead which I am replacing. it is a little bit forward of where the original dash was though.
I definitely don't want to put anything across where the old dash was because I want it nice and open. suppose i made some 1" thick plywood supports to tie the gunwales to the sides and the floor up where the original dash was. or is that pointless?
