First the boat history.
I purchased it from the original owner last year, Four Winns 4.3GL/Volvo SX with 125hrs and always garaged and fresh water only. I used it all last year - the outdrive was always very quiet when it was cold and after warming up at idle an not in gear a bit of noise could be heard. I had researched this in depth and found it was not uncommon with the SX drive.
The last trip of the year i made a grave mistake and accidently had bumped into the trim button not realizing it and then hammered the throttle pulling a skier out with the drive up to some degree - not sure how much but the bow the boat came up abnormally high. I know that's the fatal sin for a boat driver due to stress due to the u-joint angles.
After that i thought i could hear noise in the drive when at speed say 2500 rpm where i had not noticed it before (suspect u-joint, gimbal bearing, coupler?) but perhaps it was a paranoid worried conscience about the previous event!!!! When winterizing end of season last year the drive was silent at startup then after warming up 10 minutes with water running through, it sounded like when we first bought it - the subtle noise after warm up.
But this demands an inspection to see the real state of affairs. Oh the PO only had a service at 50 hours, but since that he did not pull the drive to grease the splines.
So I've pulled the drive:
1. U-joints - feel smooth as silk, can detect any looseness in them but that is hand torque loading.
2. Gimbal bearing feels butter smooth, no noise, no looseness detected
3. Splines: are dry grease on the input shaft, some mushy grease on the internal splines of the engine coupler and the teeth look "pointed" but it is not easy to see. So the question here is are they worn due to not greasing? and need replacement?
The last 2 pics show the internal spline, which to me look well rounded, the input shaft shows no wear! Is the internal spline very soft steel?
I could use some pointers in any specific methods to inspect and or service while i'm in here.
thx,
Paul
