littlebuzz
- Jun 1, 2015
- 15
Engine cranks but won't fire, Update as of 6/11, Now No spark with new ICM - not the usual culprits
Motor is a 2000 Mercuiser 3.0L (181CID), serial #0L650308
Electronic ignition
Mechanical fuel pump
New distributor cap, rotor, plugs, plug wires, and coil
Sterndrive Alpha 1, serial #0M559906
Boat was new to me last year.
Previous owner(s) removed kill switch.
Motor was running, but very rough. During winterizing, I pulled the carb to rebuild it over the winter.
Carb had rust in the float bowl and power value was frozen in place. Fuel tank was drained during winterizing and a water separator was added.
Bought carb rebuild kit, brass float, and a 2nd carb to use for parts since float bowl was in such bad shape.
Rebuilt carb and reinstalled beginning of May.
I smelled fuel and noticed excessive amount of gas in venturi.
Removed carb and readjusted float. This was tricky since all documentation was for the Nitrophyl float.
Put it all back together and it still won't start.
Engine cranks but won't fire.
Fuel does spray when throttle lever is thrown forward.
Starting spray will make it fire a little but it still won't start.
12v present at pos side of coil with key "On".
Tanks in advance,
-Buzz
Electronic ignition
Tanks in advance,
-Buzz
