Snoopyf150
- May 30, 2015
- 12
My 1987 Four Winns boat, 170 Horizon, has been in dry dock for past 7 yrs. I recently decided to get it afloat again. So I tried cranking it over but it would not start. I pulled the line from FP to carb and it was dry. That said I suspected bad FP. So I charged ahead and installed new pump, carb filter, spark plugs(pulled one and it looked bad). I also drained fuel from tank, had a "turp" smell to it. I also replaced the original anti siphon valve, fuel tank to ZfP tube and related hose. After all this I tried starting the engine with the inlet to FP hose in a fresh gas can. Nada. Checked the carb, it was dry. Would I be. Better off putting fuel in tank and connecting FP hose to it rather than the external gas can? I cannot understand why the pump isn't drawing gas from the gas can. I had the can sitting inside the boat(rear bench removed). I welcome any suggestions/recommendations. Thank you.
