Thanks, Bondo, will start there
Skydive: cold start I pump the throttle a couple times, fires right up then I run at about 1000 RPM for a few till it will hold idle on its own; warm, just crank it, usually starts without any extra throttle......Last year I was getting 4700-4800 at close to 50 MPH (boat speedo, accuracy questionable), just doesn't seem to have the same top end. I say it runs rich cuz you can really smell the fuel in the exhaust, smells like an old 70's Ford pickup......Thanks!
Update: Replaced plugs, wires, cap, rotor & fuel filter, runs great now, back to 50 mph at 4900 WOT, idle is fine. Did find a bad plug wire in the process of changing the cap, may have been the whole issue, but the tune up was needed anyway. thanks for the input!
