Rule of thumb for speed increase with increase in HP?
peter1708
Hello, I've seen a rule of thumb posted somewhere (think it was here) but I can't find it. Does anyone know of a general rule of thumb for percent increase in speed with a given percent increase in HP? This would be for mid-range 2 strokes (80-100Hp).
Assume a 25% increase in HP, any idea what speed increase would be?
Thank you,
Pete
walleyehed
Let's say you have a 100hp engine and go to a 125. You'll see about 1.47mph increase with all other parameters remaining the same.
tpenfield
As a general rule, to double the speed takes 8 times the HP. (2 X 2 X 2 . . or . . "2 to the third power"), but there are other factors that have an effect as well.
So, a 25% increase in horsepower would get you somewhere in the area of 7-8% increase in speed. . . (1.077 x 1.077 x 1.077=1.25)
Frank Acampora
Of course it really depends upon the boat and use. However, with my little 14 foot flat bottom go-fast, increasing horsepower from 90 to 125 increased speed from 50 to 55.
tpenfield
Yea, sounds about right. Mathematically you would be around 11% increase using the "cube" formula.
anzomcik
I always ball park speed increase or decrease by saying it takes 5hp to increase speed 1mph (very general terms). That is of coarse based on a boat that can already plane out and stay on plane when loaded. So it doesnt apply to low hp applications.
tpenfield
I just got about 5 mph more out of my boat. . . 47 -> 52 mph . . . It figured to be about a 150 HP improvement across 2 engines :)
Fed
Real world GPS results, 70HP to 90HP = 27Knots to 35Knots.
My gut feeling is that if I added another 20HP it wouldn't make as much difference.
