kevdog2000
- May 20, 2012
- 24
Took the boat out and it wouldn't run above an idle. Any throttle movement caused the motor to stall. I took it home and found that I'm not getting spark on cyclinder #1 but 2&3 had spark. I switched plugs and wires and had the same problem. I, then switched the orange coil wires on #1 and #3 coils and had spark on #1 and 2, nothing on #3. This told me the problem was before the coil, possibly the power pack or stator. I took a chance and bought a power pack. (Tried to do voltage checks according to manual but don't have a DVA meter, so results weren't accurate).
i hooked up the new power pack and found that I now only had spark on #3. Called the place where I purchased the power pack and they told me to recheck everything and how the pinouts should be at the connector to the coils. If it still didn't work they suggested retrying the old power pack to determine if the original results returned. Also, they said they've had new power packs that were bad and were willing to replace the defective(?) one.
Here's the weird part...when I put the old power pack back on I now had spark on #1 and #3 with nothing on #2! My question is twofold...is it still possible that the power pack is the problem or are the differing results from all the swapping pointing to a different solution for the no spark on one cyclinder?
Any help would be greatly appreciated!
1983 Johnson 75HP J75TLCTE
