Beached my boat!!!!!
MTboatguy
When I said peeling off, I was referring to if you don't fix it, nothing is going to peel off if you repair it..
:facepalm:
Arawak
The hulls are not super thick on these boats to start with... like everyone says, you will need to do a structural repair.
If it were me, and I didn't want to do a major repair, I'd feather out the edges of the damaged area, fill any deep gouges with epoxy+chopped fibers, and then lay down two layers of 8" 12oz biaxial tape with a good epoxy laminating resin. Feather edges, fair with epoxy+lightweight filler, and then gelcoat it. It will look pretty good, be plenty strong, and will not build up any more thickness that you had before.
I would not use polyester or vinylester for this sort of repair... you will need more bulk (CSM) and a wider area (poorer adhesion) to get the same strength. The cost difference will not be that significant... I rebuilt my entire 17' Bayliner with just over 5 gallons of epoxy. You'd likely need less than a quart. No matter what resin you use, do not cheap out. You won't save yourself any significant money and the structural qualities of resin tend to be inversely proportional to the price.
This repair would likely cost me $100 or less.
Homebrew72
Recommendations on what products to use? ive watched a couple of videos, seems like using a sheet cut into strips would be easier than using the mat. So many options out there makes it a little confusing.
Woodonglass
You stated the repair is 10 ft long and 3" wide. Its all along the keel. I'd recommend you do a search hear on the forum on "Keel Repair" I think you'll learn a lot. That Kit will NOT be enuf to do a 10 ft repair. Do you own a Random Orbit Sander?
MTboatguy
I guess you didn't read his very first post???:eek:
Post number 1 of this thread Wood:
"Boat took off right up the concret ramp. It ground down the gelcoat to the fiberglass about 10 ft long and 2-3 inches wide."
Darn, I am so confused!
:facepalm:
Yacht Dr.
Ok I found it. Just in case any one else is lookin for it.. Its right there in the first post!
PS. Im not sure if Im gonna make it to the forums on Monday..got an eye exam scheduled..;)
Woodonglass
Ok, I'm confused now...I think I Posted that it was in his First Post. Or is Post #31 not visible to everyone???:confused:
Yacht Dr.
I was trying to gracefully backstroke it ;) .. It was pointed out to me 3 times after the fact. I dunno but I missed it somehow. I even re-read the whole thread 3 times.
I should probably add that I wont be here Tuesday also..have a reading comprehension class...
Woodonglass
Ok, I'm gettin Older and I'm already an OLD DUMB OKIE, and I thought I WAS the one missing something!!!! I just wanted to make sure with all the other issues I'm having i didn't need to check with the Zoo and sign up with the Monkey Cages for a possible Brain Transplant!!!!:facepalm:
