Redphone107
- Jun 17, 2015
- 25
First post, but I have been following the forum for a while and appreciate all the insight. Here is my problem. We just bought a 2004 Maxum 1800 with a Mercruiser 3.0 MCM Alpha One Gen 2. The previous owner hit a stump and had $7,500 worth of insurance work done on it. They replaced the transom mount, u-joints, impeller, bellows, and rebuilt the lower and upper units. The owner put a 4-blade prop on it.
When I crank it, I have a vibration at RPMs between 1500 and 3000. At higher rpms it goes away and doesn't vibrate much at idle. The vibration happens in gear and neutral. Also, it doesn't matter the level of the drive unit. It does it all the way up through driving position (say 3/4 down). It doesn't sound funny or anything, just a wicked vibration that you can see and feel. I read about maybe the harmonic balancer being out of whack. How can I tell if that is it? Also, are there any other thoughts on the issue?
