bonz_d
- Apr 22, 2008
- 5,276
For whatever it's worth I thought I would pass this along.
As some of you know I've started working on my Alumacraft Classic and have pulled all the plywood out of it to redo it and this is what I've found.. The wood was replaced before I'd gotten this boat and the PO didn't do a very good job of it, which is why it's coming out. How long that stuff had been in there I have no idea but I have owned this boat for 2.5 years now. So last summer knowing that I was going to rip it all out I abused it to see what would happen. Actually left it out uncovered all summer as sort of a test.
I have no idea of what kind of ply this other than it's 5/8th 4 ply. I also looks as if it was painted with brown porch paint and only on one side. The underside was untreated, nothing on it at all. The top exposed side the veneer has a lot of checking in it while the underside doesn't. Every pc. I pulled up is still dry and solid. No signs of delamination, rot or soft spots. I have to say I was truly amazed! I even cut a couple of pcs. to inspect it and the wood was still clean and solid after all this time. I even took one pc. that I'm going to salvage to cut up for a small pc. to replace the missing Bow deck on the Sea Nymph I just picked up.
So before any arguments start I'm in no way suggesting that this is the way to do it or is even a good practice. I'm just relating what I have found in this case and that I am surprised that the plywood has stood up so well to the elements.
