Hello everyone. So I've ran in to a strange problem and about to go crazy trying to figure out this issue. I pulled my boat out this spring to get it ready to find out the guy that winterized it failed to do everything properly and it popped 3 freeze plugs. I finally got around to replacing those, fired it up the other night and knock on wood I think I escaped major damage. I found the oil to be 2qts low. When he changed the oil at winterization he only put 5qts in. I got the oil topped off to normal level, but now have the following issue. This is a Mercruiser 454 I'm dealing with.
So, on to my problem. Normally if you turn the key to the on position but don't start it within 7-10 seconds the alarm/buzzer will sound. As soon as you fire it the alarm should go off. Well, as soon as I fire it the alarm goes off, but within 3-5 seconds it comes right back on and constantly stays on while the motor is running and never goes off. My oil pressure is good on the gauge at 40psi. My water temp never gets over 150*. I checked my drive oil level and it's dead on.
I'm absolutely puzzled and stumped at what to check now. If anyone could be of some assistance it would be much appreciated. Thanks in advance.
