Imarudedude
- Jul 30, 2008
- 21
I recently bought a mariner 30 hp outboard Code 689 serial #418032. I have so many questions about this motor. I can't find any information on the year of the engine. Using the info on the web that gives serial# ranges for engine size and type to determine the year I haven't found one where this falls. Also the engine claims to be oil injected ( I've determined that's what the O stands for) and it also has oil injected printed on the motor cover. However when I opened it up their is no oil reservoir or place to fill oil.
I'm not sure the technical terms for what is wrong with the motor but I will explain it the best I can. I pulled the lower unit off and pulled the shaft out. That all appears to be in working order and the splines on the shaft look good.
I'm not sure what the part is called but up near the bottom of the engine where the shaft "plugs" into that "gear" appears to be stripped. I was wondering what that part is called and roughly how much it costs or if it's even possible to find.
I bought the motor for $50 and another $50 for a tank and hose. I got the motor to run but I didn't want to keep it going for more than a minute without mixing the gas because it doesn't appear to be oil injected. I wouldn't mind putting a little bit more money into it if it's going to be worth it in the long run.
Thanks for any help!
