gmstreetmaster
- Jul 6, 2005
- 12
Hello, I just purchased a 97 Bayliner Capri 1700 with 120HP Force. The motor has been replaced and has a low hour motor on it. The boat fueled up with about 4 people will do 35ish (@5000 RPM) after adjusting the trim. The prop on the motor doesn't have any markings or numbers to determine the pitch and size. The boat has plenty of power and gets out on plane really fast right now. I would like to step up the pitch to get 40- 42 MPH out of it. I mostly use the boat for cruising and sandbar hopping so no need to have a ton of power for pulling (also I could always swap props if I did).
Any suggestions on what prop pitch would be on there currently? Not sure what the stock pitch is, what pitch is recommended to get me where I'd like to be?
Thanks!
Thanks!
