My buddy and I installed freshairexhaust.com on his direct drive Malibu ski boat. 5.7L 340 hp. System hangs from swim platform. BEST thing EVER! $450 or so, but we are on the water early 6:00 am and noise level from back if boat is 1/4 of previous. No change in performance that we can tell.
It will cost a bit of $$$$, but go with the silencing tips . . . Corsa "Quick & Quiet" or similar. 454 engines do not breath all that well through the prop, so thru-hull is not a bad thing for that size engine, it is just the noise that needs a solution.
Not to change the subject from your racket making through the hull pipes but someone had no idea what they were doing when they installed the trim tabs on your boat. They're way too far inboard.
I also don't want to be that azzhole on the lake making noise. s
Captains Call install ??
I got the corsas for $200 a pair on ebay. Takeoffs of a new baja. They work well. Still a nice rumble but not nearly as loud as open thru hull
prop exhaust is the same as through hull with the exception the water muffles the sound, start your boat out of the water, with water muffs on and hear it rumble. As usual feel free to correct me.
