So I just bought a new boat, and it came with a 150cc two stroke Johnson on the back of it... Guy says it ran good but it also sat for a year. I can't read the model number or anything for parts, but that's besides the point. I have it running and I can go through reverse and forward no problem outside the water running on muffs, as soon as it's in the lake it'll run good for alittle before WOT ( wide open throttle) or full throttle. But as soon as she starts to get going through the day I guess you could say it starts bucking / jumping, kind of like a cyclinder is missing or something. And also, cruising at full throttle, for around 20 seconds you're able to and then the motor completely dies down unless you catch it and pull the throttle to idle ( which may just be a carb cleaning) but really need some input right now... Has fresh NGK plugs , gas, and oil. I'm also putting a new fuel filter on it because I took my
Old one off and dumped gas from it into a glass jar, no water in it but a lot of dirt.... Thank you in advance
