Took a file to the surface and 3 spots were recessed enough to feel it. Surface showed no file marks. Once the old gasket was removed you could see where the sealing surface was very thin,
This manifold that looks like it could be cleaned was dumping water into the stbd side cylinders for a while. took 2 starters to find it.
oem replacement and everything seems good.
