bruceb58
- Mar 5, 2006
- 30,787
BTW, the only difference between a drum brake master cylinder and a disc brake master cylinder, is that the drum brake master cylinder has a residual valve to maintain a few PSI of pressure in the lines at all times. The master cylinder does not pull brake fluid.Probably air in the line
Unlike drums that use springs to retract the pads, disc use the push-pull of the actuator cylinder to extend and retract the cylinder.
