I am trying to troubleshoot my problem. I have a 1993 135 black max. Bought it used and so far its been a great motor. Only recently the last couple of outings I have been having some issues with fuel delivery. After about 4-5 min the engine will just slowly stall out like it ran out of fuel. If I accelerate it also will die. I am thinking its probably the fuel pump because in order to keep the motor from stalling I can simply manually prime the bulb and it will continue to run.
Someone on here suggested that I unplug the fuel line from the motor and prime the bulb and see if it holds firm. I tried it tonight and it does not hold exactly firm it starts to lose pressure and simply by squeezing it again it gets full quite quickly.
Do you think it could be as simply as a bad primer bulb with the valve stuck open? What do you think?
