My 1997 Suntracker pontoon has been running okay all season but it would not reach WOT. First outing this season it would only reach about 3100-3200 rpms, figured it was a carb issue or fuel filter. Purchased a new fuel filter and plugs at the same time, when I went to install both I found the #4 plug was melted or fried (the pin exiting the plug was missing). So I figured this was my main issue for lack or rpm's. After replacing fuel filter and plugs, boat ran better but still only reached 3600-3700 rpms on last two trips since swapping them. After this last trip watching rpms slowly decrease to 3200 from 3700 on return trip home I purchased a compression test kit. Just tested last night and was surprised to find out #4 gave me nothing on the dial. Other readings were 1-145, 2-140, 3-150, and 4-0. The hour meter only shows 53 hours, I purchased this 1.5 years ago. While on the boat last season and this season I never remember seeing it overheat and I am pretty diligent about watching gauges on the water. What could have caused this?
A family member recommended trying a wet test by squirting in a little oil and trying again. Reading still showed 0 psi after inserting oil. I was told to try a leak test next and listen for leakage from oil cap and exhaust. I understand the oil cap but where do I listen for the exhaust side?
