Grumpy Bear
- Aug 23, 2014
- 58
Motor has been running very rough, won't idle right, dies when you try to throttle up in gear. Decided to check the switch box. So, the first pic is what the manual says the ohm readings should be. I set the ohm meter to 1K as directed. When I test, the readings are OPPOSITE (and still not the right number anyway). For example, in the second and third pics, I'm testing the green terminal. With red lead on green switch box terminal and black lead on ground, there should be NO continuity, but I'm getting between 3 and 4 (2nd pic). When I switch the leads, I'm supposed to get between 4 and 6, but I get nothing at all (3rd pic). Same happen s with every other test -- the opposite of what is supposed to happen, and even then, the numbers are still between 3 and 4 instead of 4 and 6.
Please advise. Is this switch box shot??
