bullheadrivercity
- Jul 13, 2015
- 1
HI need some guide ness at 78 I just can’t get everything together in my mind. My boat has not been in the water for the last couple of years. Went to start the boat and get ready for some usage and now having a problem with no power getting to the fuel pump. I traced the ground wire to make sure it was good and followed the power wire from the electric fuel pump that wire went up to a oil pressure sensor which is a 2 pin version from there the wire went up to the +on the distributer with another wire going to the started solenoid. My question is does the fuel pump only get primed when you are turning the engine over? Also is it possible to put a air hose against the oil pump sensor and blow air to see if the sensor closes to let power through? Thanks Gary
