I am in the process of maybe buying this boat. But there is an issue the owner told me about below, is this a big problem to fix?
The running lights, bilge pump, the trolling motor and the aerator are all running off the same battery. The trolling motor always works and the other three are sporadic, until water gets in the boat (normal usage water, not leakage). Once water gets in the rear by the bilge pump, the running lights, aerator start working but the trolling motor stops. I believe the bilge is causing a short. What really needs to happen is everything needs to be unplugged and rewired one at a time until the real problem is found. I know it must be minor because everything works, just not at the same time.
