drive fluid (probably a dumb question)
The drive fluid reservoir has a line on it and isnt that im assuming the fill line? its hair low on that oil and ive heard that you cat mix oils, how do i tell what i have in it now?
wahlejim
Master Chief Petty Officer
When is the last time you changed the gearcase lube? If it has been awhile, change it all out
H20Rat
A little low in that overflow tank is fine, as long as there is fluid in there. It will expand as the drive/oil heat up, so the line is more of a max line than a minimum. I'd leave it along and change it at the end of the season.
When is the last time you changed the gearcase lube? If it has been awhile, change it all out[/QUOTE I honestly don't know what that is, this is my first boat besides fishing boats with motors no bigger than a 40 horse. But the boy I bought it from takes it to a place and everything changed and checked at the end of the year
thumpar
I have mine at about 1/4" under the line. Make sure you keep an eye on it. If it starts to get lower you have a problem.
