McL0V3N1121
- Jul 18, 2015
- 43
1966 2.5L 4 cylinder Mercruiser. At the ignition coil I have ground on the "-" side post when the key is turned to the off position. When I turn the key to the on position I loose ground. I am getting 12Volts on the "+" side post. I verified this by taking my DMM red lead attached to the "+" post and the black lead attached to the negative post on the battery. If I hook the black lead of the DMM to my battery and the red lead to the "+" post on the coil with the key in the on position I get 12 Volts like I'm supposed to, but when I take the black lead from the DMM and attach it to the "-" side post of the ignition coil, no ground. But then I turn the key to the off position and I have ground at the "-" side post of the ignition coil. Where could I be losing ground to the coil when the key is turned to the on position ?
