Post # 26 suggested that there might be a problem with a scored piston.--Your pictures now prove that there is a problem-That problem needs to be addressed.----The motor will run with that but it will not run properly and will get worse,
 Having experience with engine rebuilds, it is my opinion that the cylinder wall shown is scratched badly. As the other guy said, it needs addressed, which takes you to another dimension. Sitting is hard on the cylinders by allowing rust to form, which is like tiny particles of sand. Then when it takes off running again it is a mess on the engine internally. When you look at the cylinder walls you should think ["beautiful and shiny"]-the one shown is not. With that much scaring the rings probably will not last long. Maybe a cylinder hone tool and new rings. You must be careful with this so you don't go too far causing too much clearance and mess up the ring end gaps.
I wouldn't worry about your purchase, what you are learning now is VERY valuable in my opinion. You will love the motor once you get it going. Remember: CLEAN CLEAN CLEAN especially internally.
http://www.**********/parts/detail/brp/B-0391416.html orhttp://www.**********/parts/detail/brp/B-0391170.html
Apprently iboats remove some of the link, boats dot net
Also if I would bore how much is normal and where could I get piston and rings that fit?
I would strongly suggest a service manual for you. They are tremendous tool to have for all of us.
Sounds like you have a good plan and the manual has important specs. At least try to clean those cylinders your very best and get all of the junk out that you can; maybe spray the cylinders with WD40 then rotate the flywheel by hand once or twice then wipe (towel) the walls again. I would repeat this a couple of times until the cylinder walls are as clean as you can get them to make life better on the cylinder walls and rings. Cleanliness is so very important to an engine. Coat the cylinder walls lightly with some oil before putting it back together. They make engine assembly lube just for this. If you can't get this special lube then use car engine oil so there is no "dry" startup. Try to make it last as long as you can.
Hope you get the beast running again soon. Keep us updated-love to see people fix up old stuff like this. :encouragement:
SS
