jamespjackson95
- Jan 21, 2012
- 30
Okay guys so I have a 2005 chapparal with a 5.0 gxi (EFI)...the boat was running good then all of a sudden would not start.... It appears to be not getting fuel to the injectors so I replaced the fuel cell (hp and lp fuel pump) with a new OEM one and it still does not start... The boat is not throwing any codes, and the fuel pump cuts on with the turn of the key for a few seconds, and also with the ignition. However no fuel is being pumped. I have even had both the fuel pumps 12v directly to ensure they were working and they both will cut on with 12v... The water separator was replaced and filled with fresh gas, the gas tank is full of fresh gas... The gas line going into the water separator holds fuel so I do not believe there is a restriction of fuel at the tank... I even tried an external tank with no success. I'm leaning to the pumps not working. Even though they are brand new. I swapped the relay for the fuel pump on the black box with no change, and also replaced the fuses.... What I have been doing is disconnecting the other end of the fuel lines (the two black lines with quick disconnects on the intake leading from the fuel pumps) and putting those in a small container to catch fuel. Shouldn't there be fuel coming out while cranking? Is there anything I'm missing?
