New Guy - Question
PickSix
Hello Guys, I have had a Starcraft 14' V Hull for a couple years now and finally want to gut it and make it my own. The hull is in good shape but everything else had to be taken out.
Now I'm down to just the aluminum. What I'm wanting is a basic frame and floor. Nothing fancy but something I can fish and cruise around in.
Does anyone have pictures of a floor build? Or plans?
Again it's a 14' V Hull with the ribbed bottom. Thanks fellas
GA_Boater
:welcome: PickSix
Without some pics, it's hard to throw ideas your way. There are pics of floor re-dos all over the Starcraft forum. Plans - Nah, we're guys and instructions are the last resort. :D
Watermann
Welcome to iboats Six,
First off we need to know about your 14'r and if your model was originally equipped with bench seats. You'll probably want to pay some attention to the transom wood and address any leaks.
Pics to the forum - UPDATED - Most Common Ways to Post Photos
PickSix
Here are some pics...
Update - I'm not seeing the photo icon?
PickSix
I tried the 'upload attachments' option but the file is too large. I was hoping to see the photo icon after my 3rd post but I don't see it. I'm on an iPad
PickSix
No Title
g0nef1sshn
Pics did show up. dont use pressure treated wood for a start. and Im sure someone will be able to show you a few ideas along the way. 3/4 inch BC or AC ply wood riveted or screwed the the outside end of the ribs sealed with spar or epoxy is what most of us do. But our larger ones have braces down the center hull. So I dont know if yours would bow or not in the middle with out them? Maybe seal a 2x4/2x6 to run the center to help out? Just throwing thoughts out there.
GA_Boater
I do see the pics. How about a few showing the inside of the hull. Especially where the ribs meet the side. You might be able to add a flat floor like many other SCs and maybe not.
Watermann
Six,
You're best off not trying to put the decking up to the ends of the ribs on this model. The ribs are way too high and it will become unstable. The ply that's in there now is just about the right height. You could attach the ply to the ribs with large flange rivets and be able to add some foam under the decking too but you'll need to leave the bench seats for the structure that strengthens the boats hull. From what I can see the bench seats are only boards and the boat doesn't have any flotation foam as it is right now. Or at least I can't see any foam in the pics.
fetch
PickSix
There is no foam. There was but it was old and useless along with the floor and deck that I took out.
I wondered about decking up to those ribs - awful high.
I wish I would've paid more attention to the old floor etc before pulling it out.
PickSix
If I don't end up getting a flat floor in it - couldn't I cut horizontal sections of something like horse stall mats and lay them in?
64osby
You stated it had a floor, I would try to match up to that as best as possible. Also make sure to add as much foam under it as possible.
Are there any signs that a center bench was removed. Benches provide structural support to the hull.
If there was a center bench, i would look to add some type of support in that area. Maybe a new bench, storage that ties the hull to the floor or some brackets that mount to the side and the floor.
