mr_carman007
- Aug 9, 2015
- 30
Hello,
I just purchased a new boat (new to me), its a little bit of a fixer upper. Well anyway, I got it running and wanted to test it on the lake so I took it out today. While out there 2 things happened that most definitely need to be addressed, I am thinking they are completely unrelated but I want to tell you about them both anyway... they are as follows:
1. as I was taking the boat to the ramp I smelled something burning, I quickly looked at all gauges (nothing overheating), I then looked toward the engine compartment - there was smoke coming from the engine compartment. I removed the engine cover and heard popping but didn't see any flames. (I unleashed a fire extinguisher just to be safe though). Once the smoke subsided I realized that the electrical box was very hot and seemed to be the source of the popping noise... any thoughts on what could have happened?
2. The tach showed that the motor was running at 5k rpm, however I couldn't get the boat over approximately 15 mph (wouldn't even plane out). I'm thinking this may be more of a mechanical issue with the outdrive but I wanted to disclose it in case I am missing something and somehow they're both related.
Thanks in advance for the help!
