My 1982 Mercruiser with an Alpha-I will not go into forward or reverse. This spring I had replaced the lower unit and installed it incorrectly with the shaft pointing to the left and it was thus stuck in forward. My mechanic reinstalled it properly and I drove it into the lake. Three weeks later it sits in neutral. Both cables move properly. It appears that mine is hydraulic, with a clear tube connecting to the motor marked "Quicksilver" (has two solenoids on it). On the other side of the engine is the pump for my trim. Could anyone confirm for me that I do have hydraulics involved in the forward/reverse and could it be out of fluid? If so, does the Quicksilver unit w/ the two solenoids have a fluid compartment, just like the one on the other side? If no hydraulics, what could have happened just sitting on the boat lift? Thanks.
