bonz_d
- Apr 22, 2008
- 5,276
Son just brought home a 1960 18hp Johnson FD-14 that he wants to keep and use. Of course I told him that I would help out with this. Compression on this thing is an even 100lbs on both cylinders which is great. The carb is also going to need to be done as well as the water pump. Problem is the ignition, there is no spark on either cylinder.
So far I've have taken the complete ignition plate off and have gone thru it. Removed and isolated the coils to ohm check them and they seem to test good on both the primary and secondary side. Plug wires also test good. Even ohm tested the coil secondary side thru the plug wire end after cutting off the plug wire and reseating it into the coil. Still no spark on either cylinder. So what could I be missing? Also the 2 wires from the kill button are currently disconnected from the button to the points.
