jimmwaller
- Nov 30, 2013
- 274
Hi all-
I have a 2hp Evinrude Mate. It seems to have no problem starting up initially, but there is a weird issue. It will sputter out and die, but it happens after completely different amounts of time every time. Sometimes, it will run for 2 minutes and then sputter and die, and sometimes it will run perfectly for 30 minutes and then die. Sometimes, rarely, it will run for as long as I need and then I shut it off.
When it dies, sometimes it starts right back up and then runs for another indeterminate amount of time. Had it out last week, and it died after 5 minutes, started it back up, died in like 30 seconds, started back up and then it ran for like 45 minutes, and then i started it back up and it died in like 10 minutes a few times and then I gave up.
Other times, I take it out, and after it dies, it just won't start back up. For times like these, I keep a little starter fluid with me. One time I had it out, ran great for 30 minutes, and then it died and wouldn't start back up without starter fluid. If I sprayed fluid in the intake, it would start right up but then die after a few minutes and then need more fluid to start up.
I have tried all of the basic stuff, I think. I cleaned the carb thoroughly (actually took it off and cleaned all the passages, took the mix screws out, cleaned the needle/seat inlet, etc. Also tried different mix screw positions, but i also kind of figure that a) this isn't really the issue, and b) if I set them to default, it should at least run pretty well?
This is driving me insane. Normally, when outboards run and then die, I suspect fuel starvation, condenser maybe if they have one, heat, etc. But this one.... my impeller seems to be fine and the engine is misting out the holes, I did clean the carb and the fuel flow seems to be fine. If it was fuel starvation, how would it die after a few minutes and then start right back up and then be able to run well for 45 minutes sometimes? Same with heat. If it was overheating, wouldn't it run until it overheated and then not be able to start back up until it cooled?
Any help at all or any guidance on things to check would be really appreciated.
thanks!
thanks!
