Woodonglass
- Dec 29, 2009
- 25,930
Well then, as you can see, the transom can be done from the inside with the Cap still on. You WILL need to cut back the deck about 18" on both sides of the motor well, and then cut the stringers too but...This can all be repaired quite easily and the boat won't suffer from it at all. Again, repairing the cracking on the outside is a LOT less hassle than trying to do it from the inside.
A Lot Less!!!
A Lot Less!!!
