I have a 2013 chaparall 257ssx and a 8.2l mercruiser. Been running fine for the whole summer when yesterday we were out and the motor shut right off. Gave it a few minutes then it started fine and ran for another 30 mins then did the same. After a bunch of troubleshooting I noticed that the gauges wouldnt read and the engine shuts off when voltage drops to 0. The boat will not start until the gauges start reading something (13.9v).
A little disclaimer is I think I toasted one of the two batteries a few weeks ago leaving the radio on. I charged the battery back up but I don't think it's good. However I used the second battery to start the boat for the last few weeks and the boat started and ran fine.
If I turn the key the audio system makes a beep noise. However when the voltage is reading NODATA it doesn't beep at all. I checked the terminals on the battery and the electrical to the switch? And nothing is loose. Everything else electrical works fine, its almost like the engine isn't getting the power however it turns over fine just won't run.
Thanks
Thanks
