I have 3 rivets Ive removed due to leaking , Im hearing truss head or pan head bolts( with washer) is a good fix in lieu of rivets. Stainless is best with 5200 as a leak preventer and I assume a barrier for galvanic corrosion. I have access on inside of hull and using thread lok nuts. I found an old post here from 2002 ,FlyBoyMark who uses this method. An old salt at the boat shop said they would build them like this but too costly. I have concerns about the corrosion,Ive seen it without a barrier on bare alum. Any thoughts appreciated.
