Hey Folks, I found many threads similar to my issue abut none is my actual issue.
I've 2004 Mercruiser 3.0L, Alpha 1 gen 2..
The boat would rev up to 7K RPM WOT and only would get up to 25 MPH..
I changed the prop and hub thinking it might be spun and even 20" pitch from 17" and still no hope..
I changed the oil, oil filter, gas filter, plugs, gear lube, cleaned the carb.. but no hope.
could be the coupler? never smelled rubber or anything!!
I did a compression test and all 4 cylinders read 120...
the boat runs fine, but soooo slow, 7MPH at 4K RPM, oil pressure is less than 40 PSI, around 30 PSI, could that be any issue too?
any idea?
thanks
any idea?
thanks
