am_dew
- Apr 3, 2005
- 417
I had bought a new grease gun and after adding a few squirts of grease into one of my Bearing Buddys I tried to remove the grease gun fitting but it would not budge no matter what I did while also being careful not to damage the BB. I ended up holding a large flat head screw driver head against the BB and gently pulling on the grease gun fitting to try and get the fitting off the nipple. It finally came off but in doing so, the BB's grease nipple broke off and was stuck in the grease gun's fitting. The result was a 1/4" hole in the face of the BB. Big trouble and to make things worse, this was the morning I was about ready to tow my boat about 200 miles to a vacation spot. I did not want to have to replace the BB so I got creative in my thoughts about needing to seal that hole. I ended up inserting a very short bolt with a small washer under it into the hole in the BB and then generously applied JB Weld under and around the bolt's head and the washer, and then waited for the JB Weld to harden before we left. I stopped several times along the way to check to be sure everything was holding and no grease was leaking. Obviously, I will need to replace that BB, but my fix worked well and got us to and from our vacation spot. Be careful about the grease gun you may buy and try it on something you don't care about before using it on your BBs!
