Hello all,
The motor has been running great until last Saturday. Started it up took off, went to WOT and the engine died. The pull card would not pull at all. Great a frozen engine
I thought. I took the pull cord assy. off and it worked fine. I tried to move flywheel, and it wouldn't budge. Put a wrench on it and freed it. The pistons where moving up and down, however the flywheel would stick at times, until finally it froze again. I assumed a bearing, so I started pulling it apart. Took the cylinder head off and found aluminum metal chips. (see Pic). The cylinder bores are smooth as silk. What on earth is going on?
Thanks,
Guys
Thanks,
Guys
