Hi
I have an old Draco 2100SC with a 2000 Volvo Penta 4.3 Gi PEFS (Dark grey color), with DP-C1 I/O drive.
Yesterday I had no luck starting my engine. The day before it started on the first turn of the key.
When the ignintion key is turnet on, usually the instruments come on, and the fuel pump does its's thing. But yeasterday it was completely dead.
This happended once before (The last time I used the boat) but after pulling all fuses and connectors I could find, it started right up. I did not do this in steps, with an attempt to start in between, so I have no idea what actually caused the error.
Yeasterday I tried the same, but no result. Still dead. Exept for one short sign of life, when the pump started and I could engage the starter for a few seconds. Then it was completely dead again.
Battery voltage is OK.
I will first check the main power switch between battery and starter, althought I tried jumping this with a car jumper cable yesterday with no apparent success.
Does anyone now if the main fuse is known to fail? This is a 50A automatic fuse, with push reset.
Also I was wondering about the relay in the fusebox on top of the motor. Would a failed relay cause similar errors?
All help appreciated!
