Chinewalker
- Aug 19, 2001
- 8,902
No Title
I think I may have a work-around for several of your issues. The low transom, regardless of whether you use a jack plate or not, will be a liability when it comes to water coming over the transom. If you build some coamings into the hull, and integrate them into a taller transom, you can effectively raise the height at which water would have to come up to to be an issue. Running the coamings full length of the cockpit would also tie the transom into the hull, add rigidity to the hull, and make for an overall more stable boat with less flex issues.
Something along these lines:
