San_Diego_SeaRay
- Nov 9, 2014
- 343
Engine: 1981 Merc 260R MCM 350 (Rebuild project; hasn't actually been in the water yet)
Two questions if you could help:
- I hook up my Ohm meter probes to the Coil+ and then ground. I get 7 ohms. Then I push down on the shift plate mechanism to complete the cutout circuit and I get 0.1 ohms. On my other engine (there are twins), I get Infinite ohms, then push the shifter to get 0.1 ohms. Shouldn't the 7 ohms be Infinite ohms as well? Is my coil grounding out thru the Distro? Or is my cutout switch bad? Or is this completely normal?
- I bought a harness (canon plug) for one of my engines. It was explained to me that w. this harness I'd need to run a wire from the "S" terminal on my starter up to the B+ on my coil. Question is, how did Mercruiser power the coil at startup with this harness design?
