Woodonglass
- Dec 29, 2009
- 25,930
Remove the steering from the motor. Replace the transom. Got pics of the steering hook ups on the motor AND the Console??
The SS rod that goes clear through the tilt tube comes out. Be sure to turn the wheel draw it all the way in before trying to pull it out, that way it's shorter and will come out of the tube easier. Afterward be sure to clean that tube out really well and lube it.
On the console steering cable, rotary or rack? should either have a screw on fitting or a pin to push in to remove the cable. Once it is off pull it from the rear. If you are planning on replacing it you can also cut it in pieces to remove it.
That pour in foam removal sure is a dirty job.
