bob johnson
- Feb 25, 2009
- 4,306
I am wiring up my boat and I have the two batteries under the seat I am making for the drivers helm. I don't know the exact length, but my steering cable from Teleflex was a 20 ft version....the battery cable starts a little closer to the stern but it has to snake its way up and into the motor...so I am guessing the cable will need to be about 20 ft. the manual says that cables should not be more than 20 ft!! and they recommend 1 gauge for 20 ft....
can I install a battery switch at the stern and run big cable to that... then run the slightly smaller wire from the switch up through the motor harness passages ( small)
to the starter?? Its not a cost issue...its an issue of getting that BIG cable through the passages and opening into the motor and along the side of the motor to the starter...
I REALLY want to keep the batteries up front!!!!!!!!!!!
thanks
bob
thanks
bob
