Lukelona
- Mar 9, 2013
- 449
Ok guys, cleaned all battery terminals, the better battery that was in it had bad connection this whole time. I turned switch to just the better battery and hit key, it would lose connection and is have to wiggle terminal. Put brand new marine battery from my other boat and put it in, took the crappy older battery out and put the almost new automotive battery in with the marine. Following me? Lol
took it out for a couple hours test run.
As soon as launched, checked voltage via multimeter. It was charging little above 12v
Drove it around for a while, batteries don't drain at all, but multimeter still reading about 12.3-12.5 give or take.
Well after about an hour, I had stopped for a min, then took off kinda fast and boom, the gauge shot up to halfway mark, and I stopped again (to check if something bad happened lol) and checked voltage, it was reading 13.5-14v! This is where it should be probably?
Took off again and it stayed charging good for about 10 min then slowly went back down towards where it was reading (12-13v).
So I'm lost now. Does the regulator only kick on when batteries start to drain, then kick back off? Is the regulator going bad? I'm not trying to get stranded due to low voltage lol.
