Hello everyone. Here is my current situation. I picked up a 1993 Johnson TJ115TLETS from a friend and I finally started messing with it 2 years later and here is what I found. It would crank up and idle fine but trying to get the boat on plane it was just dragging and you could tell it had nowhere near full power. I came home and performed a compression test and I had 100,100,100,80 lbs. I pulled the head off with the bad compression and found a burned piston.
Here are my questions
#1 what caused it? Lean Condition?
#2 If I rebuild will I need to have it bored or just replace rings and piston?
#3 If I do rebuild would you do all or just the burned one. From what I can tell the head on the bottom looks as bad as the top. I am wondering if someone already replaced the bottom piston.
#4 Is it worth Rebuilding? I can get parts as cost +10% but even with that we are talking 200-500 depending on what I do.
My friend sold it to me very cheap because he bought it for the boat and wanted rid of the motor and controls.My friend also told me he would buy it back but he is currently in hospice and I am not going to bother him. I know I can part it out and make my money back but I hate to do that do such a good looking engine. Any help will be greatly appreciated.
