Just purchased 2000 Maxum last month with Mercruiser 7.4 MPI. When I start it, it runs for a few seconds then dies. This happens severals times until it finally stays running. Engine runs great, even when idling, its just the start process. If I turn off engine and restart a few minutes later, same process repeats itself. Previous owner showed me receipt that, IAC, fuel pump, shift cable, and water pump assembly was replaced in July. Took it to mechanic, and they feel that the fuel injectors need cleaning or replacement. Any thoughts? Thanx for any response. Also, the mechanic says 3-4 hrs labor, $125 per injector to clean, or $300 per to replace. That seems kind of steep.
