Lukelona
- Mar 9, 2013
- 449
Hello, helping my nephew fix his boat. It's a 1993 stingray 609 with 4.3 mercruiser/alpha gen 2 drive.
Recently while flushing engine it started making a knocking sound from outdrive.
Today I pulled the drive and ran it without and it didn't make the noise. So it's definitely in the drive I believe.
It happens at higher rpms in N and in drive it will make the noise either way.
It starts around 2k RPM. Sounds like it's coming from upper half of outdrive, the gimbal bearing is new and still perfect, the u-joints look good and only one has very minimal play on it. I took the top cover off and visually inspected the gears coming from driveshaft and they look good, no broken teeth etc. Also the bearing under that cover (don't know the name) feels good also.
This outdrive is exceptionally clean, no corrosion and seems to have been well maintained.
I also checked drain plug magnet for metal and only found normal very little shavings.
I'm stumped how to proceed diagnosing it.
Any help would be great, thanks
