Lakelife75
- Nov 9, 2015
- 5
I need some help, I traced the problem to no coil voltage when I start. I get no voltage at purple wire going to coil when starting, so I jumped 12V directly to the purple wire and it fires right up, but cuts off if you disconnect it, first suspected slave solenoid, but then realized that shouldn't matter after it's started. I have 10/11V on yellow/red wire coming of starter solenoid when switch is turned on. I first thought it was the interrupter switch, but realize it only closes contact when putting into gear, and I think it goes to ground then. Can that switch be bad and staying grounded? I am getting continuity from purple on alternate to purple on switch, and just happened to put meter on 2 screws attaching switch to motor and get continuity there. Also jumped out safety switch at gear shift, that does not fix it.
Any other ideas.
Any other ideas.
