Hi all,
I have a 1978 115 hp Johnson that seems to slip under load (towing - I can't think of the "C" word for the process.) and you have to drop off the revs to pick up speed. Anyway the engine seems to run fine but at WOT it is doing roughly 80 km (50mph) at 6500 rpm. This is to high rpm isn't it. The prop is 17'. Should I put a higher prop on it to bring down the WOT rpm?? and also increase the potential pulling power without it (That C word again). What should the WOT RPM be on the old girl???
Regards
Peter
Regards
Peter
