I have a 2000 Sea Ray 270 Sundancer w/ a 7.4L the engine serial is 0L621950.
I just put the boat back in the water after having the transom seal replaced, it runs fine but when I raise the RPM's up to get up on plane the alarm system starts a pulsing alarm that will not stop until I shut off the engine. Turn the engine back on and once again all is good until I raise the RPM's. I disconnected the drive oil sender and no change, the oil pressure and water temp gauges show normal. The owners manual doesn't tell me what a pulse alarm means just that a solid alarm signals trouble. Any ideas what to check? I would rather fix it myself than take it back out of the lake if possible.
Locke
Locke
